630 Clutch operating sleeve drive pin hole repair
Tyler-MO
09-27-2004 20:39:51
Well I tried to get the condensed version in the subeject line. I have a 630 gasoline that upon the removal of the clutch pulley assebmly, I found a very worn clutch drive pin hole. The pin also appears worn, which I"ll undoubtedly replace.
My question is once I remove the drive gear from the clutch pulley (not a problem with a 20ton hyd puller), what is the best way to repair it. Can it be welded, drilled out & bushed??
Any experiences or thoughts???
Thanks
Tyler in Missouri
Tyler-MO
09-27-2004 20:44:46
 Re: 630 Clutch operating sleeve drive pin hole rep in reply to Tyler-MO, 09-27-2004 20:39:51
third party image
Link
Tyler-MO
09-27-2004 20:49:45
 The picture of the sleeve is in parts pieces in reply to Tyler-MO, 09-27-2004 20:44:46
it's under 630 john deere
