G clutch driver
Ken C.
09-27-2004 18:36:33
My clutch driver has slack in it, and i saw an ad where you can get under size drivers, several sizes. How can you determine what size you need. The splines look good on crank, could be driver worn mostly, anybody know how to check crank size. Any help is appreciated, Ken.
Goodwrench
09-28-2004 12:26:55
 Re: G clutch driver in reply to Ken C., 09-27-2004 18:36:33
Measure the crank & its taper, then call one of the retailers and ask what the spec range of the driver is. Although it seems hard to tell given the seemingly neat splines on the crank, they are usually worn some if the driver was run loose. They are a taper fit & should sit out from the end of the crank roughly 1/8 inch when properly seated.
Ken C.
09-28-2004 19:47:00
 Re: G clutch driver in reply to Goodwrench, 09-28-2004 12:26:55
Thanks Goodwrench, the 1/8 distance tells me i have got lot of slack mine goes passed the crank some, i will give them a call, thanks again.
