430W PTO keeps running
Scott Law
09-27-2004 16:00:12
The PTO on my 430 keeps running when the lever is in the off position. It runs at the standard 540 rpm when in the on position. When the selector lever is placed in the off posistion the PTO turns slowly. I would guess that the clutch is still slightly engaged when it is in the off position. Is this something that can be adjusted? Or is it a major project? The clutch seems fine and the tractor runs and shifts into gear normally.
buickanddeere
09-29-2004 06:09:23
 Re: 430W PTO keeps running in reply to Scott Law, 09-27-2004 16:00:12
They all do it. There is enough thick oil dragged along with the shaft splines to spin the pto output shaft/shifting collar which is in close proximity.
Henry J
09-27-2004 17:03:00
Scott
It is common for the pto shaft to turn slowly when not engaged and not hooked up to something. The lube is doing this inside the case.
Take something like a 2X4 , stick one end on the ground and rub the rotating shaft with it and I bet it will stop turning, all should be normal then.
Oh and safety first, don't let that shaft grab you or your loose clothing.
Let us know
Scott Law
09-28-2004 09:35:39
 Re: 430W PTO keeps running in reply to Henry J, 09-27-2004 17:03:00
Henry,
Thanks alot. I'll give it a shot. I'll be careful not to loose any fingers, or arms in the process. I'll let you know how it goes.
Scott
