3020 conversion to negative ground
Neal P
09-27-2004 10:27:53
What do I need to do to convert a + ground system to - so I can install an electronic ignition.
John T
09-27-2004 12:41:21
 Re: 3020 conversion to negative ground in reply to Neal P, 09-27-2004 10:27:53
Neal, I pretty much agree with the good advice below concerning swapping the battery cables and re polarizing the Generator and can only add a few comments. If it has an ammeter versus an idiot light charge indicator (think it just has an idiot light, however right???) its leads would also have to be reversed so it dont read bass ackwards. To insure the Gens Field is grounded when you polarize (after reversing battery and hooking things up) temporarily dead ground the Gens Field post to its case before you momentarily jump the VR"s BAT terminal over to its GEN (or ARM) terminal and you ought to get a small spark.
If the fuel gauge is a bimetal heat type gauge its polarity wouldnt matter, but if its a galvo type, the wrong polarity can cause needle deflection in the opposite direction. Try it n see what happens.
Normally I would say to reverse the coil leads with - to distributor, but if its an internally ballasted 12 volt coil (not a 6 volt coil and an external ballast system) I cant say for sure what to do, it will work, so try it both ways and see if you can tell any difference. My thinking is if its internally ballasted I dont want the ballast between the coil and points, so not knowing how its internally wired (or if its a 6 or 12 volt coil) Im hesitant to offer a suggestion.
I was thinking Deere stayed at POS ground (even with the New Generation Tractors) up until they switched to Alternators, so guess you have a gen not an alternator right???
John T
Gerald J.
09-27-2004 20:43:33
 Re: 3020 conversion to negative ground in reply to John T, 09-27-2004 12:41:21
Just an idiot light on the generator. Either no resistor or an external resistor. My 4020 gas has an external resistor and a contact on the starter solenoid that shorts it for better ignition when cranking. Other than putting on an alternator, what I posted is ALL that I did to my 4020 besides switching the leads on the ammeter that I added.
New generation tractors with cabs often came with alternators and negative ground, unless diesel. Then they generally were 24 volts mid ground, but later went to 12 volts and JD still sells a kit for that conversion.
The owner's manual says only jump from battery to armature terminals on the regulator for flashing. With the generator not running the regulator should have the field solidly grounded. If it isn't the regulator is bad. After rebuilding my generator and adding the ammeter, I couldn't read the ammeter because the regulator was so slow the ammeter bounced from pin to pin. A 10SI alternator was only half again the price of the regulator and now I get several years battery life because it charges properly and quickly. The generator was only rated at 20 amps. Good for taking half a day to charge from one start, but not fast enough for keeping up with utility tractor use.
Gerald J.
John T
09-28-2004 09:11:59
 Re: 3020 conversion to negative ground in reply to Gerald J., 09-27-2004 20:43:33
Gerald, I havent seen ya since we met at Brian Vickers trailer long ago at Expo in Waterloo (thats right isnt it???). Maybe we can cross paths again. John T
Gerald J.
09-28-2004 10:06:47
 Re: 3020 conversion to negative ground in reply to John T, 09-28-2004 09:11:59
That's right.
Gerald J.
Gerald J.
09-27-2004 10:55:38
Swap the battery cables. Might need new cables because the posts are different sizes.
Swap the coil primary terminals. + goes to battery, - to distributor.
Flash to generator (hook a wire temporarily for a second or two from bat to GEN or A terminal on the regulator before starting it.
Use it.
Gerald J.
Bob
09-27-2004 10:52:48
If you have a generator, you should be able repolarize it to the new polarity before starting the engine after switching the battery cables.
If you have an alternator, you'll have to replace it.
Switch the coil connections so (+) hooks to the wire from the ignition switch at the same time you're installing your ignition.
There may be accuracy issues with the electric fuel gauge after the switch to negative ground.
