Governor
Wes Suksdorf
09-26-2004 17:29:21
I changed the bearings on my governor and then put it back together. Now the governor doesn"t do anything. It used to be that I could idle way down and the governor arm would keep it running. I asked a member of the local tractor club what to do and he said tht the arm inside the housing is in the wrong place. I have a parts book and operators manual but they don"t show verygood pictures. Can anyone tell me what I did wrong? It is on a 47 A.
Wes
Greg S
09-27-2004 12:57:03
 Re: Governor in reply to Wes Suksdorf, 09-26-2004 17:29:21
Wes, Send an e-mail to me and I will return a picture of the inside arrangement of an early styled B governor. This is as close as I have a picture of at the moment.
Marty Z
09-26-2004 23:04:19
My neighbor had the exact same problem. the forks on the gov. weights were in the wrong location when he istalled them.
Simple Fix.
MJZ
Mike M
09-26-2004 18:17:24
Without seeing it I can only make a wild guess as to what to check. One thing I have seen done before on A's was that some people have put the weights against the thrust bearing when they were suspose to push on the bottom of the sleeve the bearing goes onto. If your tractor is a pressed frame model it may not use this type of sleeve. Can you post a picture of the governor ?
