40T Dual Touch-A-Matic Pulsating
krk
09-26-2004 12:59:21
Having a problem with my Dual Touch-A-Matics pulsating after it the 3 point gets to position. Selector lever under left side of seat is set to forward position. The load control is screwed out to keep the load control from working. The left touch-a-matic lever is set to the rear position. The Right lever will raise and lower the implement smoothly but once the implement gets to its position the 3 point pulsates. I have played with the turnbuckle for the loadcontrol but cannot seem to find a position to stop the pulsating. Any help would be appreciated.
buckeye al
09-28-2004 14:57:25
 Re: 40T Dual Touch-A-Matic Pulsating in reply to krk, 09-26-2004 12:59:21
USUALLY when this problem is encountered in these units, the check valves are bad. Those units have several plugs held in place by wire C clips. Behind those plugs are spring loaded check valves that must seal to keep the rock shafts in the raised position. When using it in the mode you state, a leaking check valve on either cylinder will cause them both to fade down. The control rods will then close the delivery ports & re-raise the implement. It simply repeats & the implement bobs up and down as long as the engine is running. You have either leaking piston seals, leaking head gaskets (not generally the case) or a leaking check valve or valves. There is a test for what is leaking. You first attach an implement & raise it. SAFELY hold the implement in the raised position with a jack, blocks, hoist or whatever is required, just be safe. Shut off the tractor & lower the operating handle to remove the pressure from the cylinders. There are 2 half inch pipe plugs on the unit, one on each side near the top rear as I recall. Remove those pipe plugs & deeper into the hole is a threaded section where you can screw in 3/8 inch pipe plugs with an allen wrench. These plugs will trap the oil in the rock shaft cylinders. Remove your jacks or blocks or whatever to again let the weight of the implement hang on the lift arms. If it stays in the raised position, your problem is leaking check valves. If it still falls, you have leaking piston seals or head gaskets. Check valves can usually be fixed by hand lapping them back into a good seal condition and usually they are the culprits.
Suggest looking at the Deere service manual for these units. It will be very useful. Just about a year ago I overhauled my 40 two row utility's unit. It was worth it!
Wayne in Tn.
09-26-2004 14:35:13
Do you also have the left lift arms pinned together? The check valves not seating properly can cause this, also a worn spot on the control valve. The check valves, crossover valves and shuttle valve are the only ones you can check without tearing the unit apart. You really need the service manual to do much to this system. You can remove the check valves, clean them and the bores, lap them a little with a soft valve grinding compound, clean and reinstall, this could stop your problem, if not then a tear-down will be next.
krk
09-26-2004 14:53:45
 Re: 40T Dual Touch-A-Matic Pulsating in reply to Wayne in Tn., 09-26-2004 14:35:13
The lift arms are pinned together and both pins are against the selector lever.
Wayne in Tn.
09-26-2004 14:37:53
Also use a pair of pliers and make sure the crossover valves are pulled out and touching the stops on the lever under the left side of the seat.
