'47 D running rich
Mark Scholten
02-05-2004 17:45:09
Replaced the head gasket last weekend and got the engine running. It runs pretty well but it really smokes up the garage with blue smoke. My eyes burn and that tells me the fuel is rich. It ran good before I tore it down. The carb has been gone through. I did dump about 8 ounces of Marvel Mystery oil into the gas tank which had about 10 gallons of gas in it. Timing is good. I wonder if opening the gap on the plugs a scosh (hope that's not to technical) would help? Maybe when I aired up the front tires I raised the front end to high!!!
Thanks in advance for any suggestions.
Mark Scholten
Sparta, Michigan
old
02-05-2004 18:33:39
 Re: '47 D running rich in reply to Mark Scholten, 02-05-2004 17:45:09
you may just need to adjust the carb a little, every time you do something to and engine you need to adjust other things to get them in sink with what you did
