DLTX-71: how best correct the float level?
wilhoit
09-25-2004 19:33:35
I'm rehabbing a DLTX-71, according to the instructions in JD publication SM-2000, Section 60, Group 15. This carb had a history of delivering excessive fuel to the engine, which then ran through unburned into the crankcase.
The needle valve and seat are new, from Doug Burrey.
I have reached the point where you check the float level by turning the reassembled bowl upside down. By this test the float is 5/16 below the rim of the bowl WITHOUT gasket.
1) I have read somewhere that the correct level is 3/8 WITH gasket; is this true?
2) Lacking "Bending Tools A1832R", (whatever in the foggy blue morning those may be), is there a clever way to bend the float arm without taking the float back out of the bowl?
Thanks in advance,
FW
Duane Larson
09-25-2004 20:06:01
 Re: DLTX-71: how best correct the float level? in reply to wilhoit, 09-25-2004 19:33:35
wilhoit,
The matter of importance is the level of fuel in the carburetor, and it is not particularly accurate to adjust that by measuring the float height. You should do the test discussed on page 60-15-10 of your reference to determine the fuel level in your bowl. To bend the float so the level is higher, with the bowl upside down I just gently push the arm down (assuming it has a chrome needle and not a viton tip). To go the other way, I jam a screwdriver under the back of the float arm and push up. The tools to which you refer are shown in Figure 60-15-25.
I will also note that I have learned to check needle and seat units before selling them by pulling a vacuum on the unit. It is not at all unusual for a unit to not hold vacuum, and that normally means the unit will leak fuel also. Some chrome needle units can be fixed by inserting the needle in the seat, and dropping a 3 lb hammer on the needle from about 6" height. Others require polishing in the lathe with aluminum oxide polishing compound. And occasionally I find a new one which simply will not seal. This is an aggrevating problem - new stuff should work!
It is also possible your bowl has a crack in the region where the seat screws in. Those will leak no matter the condition of the needle and seat, but can be fixed by cleaning and using a thin layer of JBWeld or gas tank sealer or what ever your favorite sealing goo is.
