JD 1518 Batwing (wing hinge pins)
Jason Z in MO
09-24-2004 20:08:50
I have a 1518 that has a broken wing hinge pin. I have the wing blocked up and trying to remove the first pin to get to the one broken. Anyone have and experience driving these pins out???
They are in the pivot area and can"t get a big enough hammer down there to free them.
Thanks for any suggestions!
jd4960
10-04-2004 09:00:50
 Re: JD 1518 Batwing (wing hinge pins) in reply to Jason Z in MO, 09-24-2004 20:08:50
I have had plenty of exp. at removing those pins did about 15 of them the first year I worked at the dealership. more often then not you have to cut the whole hinge off the deck. Then reweld new hinges on They have an update on them. They first went with a continous pin all the way thru but now the pins are undersized. It is a pretty big job because most of the time the pins are froze up in at least 1 hinge or the other and it usually means that you have to do all the hinges just make sure that you mark the hinge positions and the height of the hinges so when you realign them they are back at original position or the wings will not raise all the way up have fun!!!
