3010 No brakes when not running
sheadee
09-24-2004 13:07:45
I recently purchased a 3010 tricycle. I put in food plots in some hilly terrain of north central PA. I'm converting to a wide front, but was told (now)that there is no brakes on this tractor (& 4010)when these things aren't running. Is there an emergency brake hook-up that can be installed? (?atinuator?). I get a bit crazy while "playing" and would hate to experience coming down "the powerline" w/out brakes if this would cut out or run out of gas on me (potential death!)... Help
John51
09-25-2004 17:53:23
 Re: 3010 No brakes when not running in reply to sheadee, 09-24-2004 13:07:45
Where in nc PA? I"m close to Williamsport, can show you about the brakes.
sheadee
09-27-2004 06:33:19
 Re: 3010 No brakes when not running in reply to John51, 09-25-2004 17:53:23
John51, My cabin is in Canton. I just read the other responses. They basically state that there will be brakes and steering, just EXTREMELY difficult to muscle (I guess similar to a car). I was originally told these 2 tractors don't have ANY brakes/steering when not running. That scared the h$ll out of me. Someone said there is a way to rig up an emergency break w/an atinuator? I just got rid of a 2010, I hope I didn't buy another headache.
Gerald J.
09-24-2004 18:09:38
Brakes and steering disappear more rapidly when the check valve in the transmission fails. Then they go away while the clutch is pushed. There is a cure for that check valve on my web page.
The thing to do on the ridge when the engine stops is use the little braking left (and it won't be powered, it will take MUSCLE) stop, shift to park and start walking after fuel. Steering won't stay long either and won't be power but purely manual requiring MUSCLE.
Both brakes and steering hold oil for manual operation without hydraulic pressure, but the difference in effort is drastic.
Gerald J.
DON
09-24-2004 14:45:22
THAT TRACTOR HAS MANUAL BRAKE'S (PUSH HARD) FOR A SHORT TIME. TWO OR THREE APPLICATIONS IF THE BRAKE VALVE AND OR PISTON SEALS ARE GOOD. FIRST THING I WOULD DO IS OVERHAUL THE BRAKE VALVE . IT ALSO HAS MANUAL STEERING AS WELL.
