4640 gearing question
Bill J
09-24-2004 11:27:22
I just bought a 4640 powershift that has had 18.4x42 rear tires put on it. It originally came from the factory with 18.4x38's. My question is did these tractors come with different gear ratios according to which tire size they came with? The previous owner said he just switched the tires and not any gears? I'm wondering if a gear ratio change was necessary too. Thanks for any help
Bill
G-MAN
09-24-2004 13:50:43
 Re: 4640 gearing question in reply to Bill J, 09-24-2004 11:27:22
No, there were no alternate or optional gear ratios for the 4640. With bigger tires you're going to run faster in any specific gear, as larger tires make the overall gear ratio "higher".
John Jenkins
09-24-2004 11:48:16
I have a 4440 (Quad-Range) that came with 18.4 x 38 rears, long axles and hub duals. In looking at tractors equipped with 42s, they actually don�t look very much taller than the 38s. I think this may be due to a lower profile sidewall on the 42s. In any case, I�ve never heard of anyone changing the gearing to accomodate a tire on these machines. It�s not like they don�t have the power to run whatever you want. We used to have 2 4430s (both were Synchros), one with 18.4 x 38s and the other with 20.8 x 38s and 4th gear on the 20.8s was almost as fast as 5th gear on the 18.4s. My point...change gear ratios by shifting down (or up) to compensate. Good luck.
