Clooney, John T. or anyone
Dave in Ohio
09-24-2004 07:36:17
I have a leak on the high preasure line coming from the hydraulic pump on a styled AR. I can see part of an O ring that is sticking out on the outside. My question is, 1. Can this be fixed with the pump still on the tractor and if not
2. What is the process for removing the pump and installing a new O ring.
3. What kind of trouble can I expect once I pull the pump cover off. Thanks for all help
bent
09-24-2004 08:29:57
 Re: Clooney, John T. or anyone in reply to Dave in Ohio, 09-24-2004 07:36:17
You will get more complete answers but I can tell you what I know. Those lines coming out of you hydraulic pump are just stuck in there about an inch and held in place by a thick washer and cap screw. If you can see the O-ring, then the line is not seated enough and it is possible that the thick washer and cap screw are missing. The thick washer will hit the lips on both lines to secure them. It is kindof an awkward spot to work on but cleaning up the lines and replacing the o-rings has worked for me in the past. You have to wiggle and twist the lines a bit to get them to move. I have seen all kinds of things done in this area including brazing around the point where the lines meet the fitting and I even have an old pump here that someone welded hydraulic couplers right to the pump. Good luck.
BRent
