1952 g john deere lower water pipe to water pump
john chapek
09-23-2004 19:44:00
i have a 1952 g the lower water pipe that goes from the head to water pump ihave a new pipe with two rubber orings that are on each end whats the easyest or hardest to install
Bryan Breland
09-23-2004 19:49:22
 Re: 1952 g john deere lower water pipe to water pu in reply to john chapek, 09-23-2004 19:44:00
Just clean the groves and pipe ends well, install the new rubber o rings and apply some grease around the pipe and o rings to help slide together without damaging the o rings. I slide the radiator end in first then slide back into neck on head.
