Hydraulic pump on styled AR
Dave in Ohio
09-23-2004 15:59:17
I have a leak on the high preasure line coming from the hydraulic pump on a styled AR. I can see part of an O ring that is sticking out on the outside. My question is, 1. Can this be fixed with the pump still on the tractor and if not
2. What is the process for removing the pump and installing a new O ring.
3. What kind of trouble can I expect once I pull the pump cover off. Thanks for all help
Mike M
09-23-2004 16:47:00
 Re: Hydraulic pump on styled AR in reply to Dave in Ohio, 09-23-2004 15:59:17
You should be able to unhook that line without removeing the pump as on all the other models you can.
