4010 Steering
Whitefield
09-23-2004 07:06:00
This tractor sat for about a year with the steering lines unhooked-well loose. Now everything steers fine, but, I believe there is some air in the system yet. When starting, the steering wheel will turn about 2 revolutions- the tires don't move, just the steering wheel. Then when you shut it off the steering wheel will gradually go back those 2 revolutions. When the tractor is running- there is no problem at all-it steers just fine. Is there some way to bleed this if that is what needs to be done- couldn't find it in the S.M.
Thanks again everybody.
DON
09-23-2004 08:47:27
 Re: 4010 Steering in reply to Whitefield, 09-23-2004 07:06:00
REMOVE THE COWLING. ON THE LEFT SIDE OF THE STEERING VALVE THERE IS A HOSE BARB. RUN A CLEAR PLASTIC LINE BACK TO THE FILL HOLE ON TRANNY. LOOSEN THE LOCK NUT ON THE HOSE BARB, THEN THE HOSE BARB, AND WITH THE STEERING IN A FULL RIGHT TURN HOLD THE WHEEL FULL RIGHT UNTIL ALL THE AIR BUBBLES ARE GONE, THEN WITHOUT MOVEING THE WHEEL TIGHTEN THE HOSE BARB. NOTE HOW TIGHT THE HOSE BARB IS WHEN YOU LOOSEN IT. THE HOSE BARB TIGHTENS AGAINST A STEEL BALL SO IT DOESNT NEED MUCH FORCE TO HOLD. OVERTIGHTENING CAN RESULT IN DAMAGE TO THE HOSE BARB. HOPE THIS HELPS. DON
