40T Carb Problem
J Bennett
09-23-2004 04:27:02
My 40T will crank and run fine with the choke out, but will quit when you push the choke halfway in. Any advice on where to start to correct will be appreciated. Thanks, JB
gil
09-23-2004 21:59:47
 Re: 40T Carb Problem in reply to J Bennett, 09-23-2004 04:27:02
I had the same problem with my 56 420. I used a series of small drill bits by hand to ream out the holes in the carb. The smallest hole in mine was plugged up so I was getting no fuel at idle.
Take care. JD Earl
CPeter
09-23-2004 19:07:33
Also check the scren in the inlet fitting on the carb. As to the jet that Duane was talking about, I ground a screwdriver to just fit that jet. I just put a 420 carb through the electrolysis tank and it did a real good job. Cleaned out the drill holes with drills(hand held) and flushed with laquer thinner and blown with air. Worked great. Ran like crap before and now is perfect.
CPeter
Duane Larson
09-23-2004 05:33:06
J Bennett,
In addition to Wayne's suggestions, make sure your air cleaner is functioning properly (not plugged), and you may have a problem in the idle circuit of your carburetor. The TSX has an idle jet located at an angle near the venturi hole in the top part of the carb (you will have to take the top off and turn it over to see the jet). To test for proper idle circuit operation, squirt some carb cleaner into the jet and see if it comes out the small holes above the venturi. If it does not, your idle circuit is plugged. Be very careful removing the jet, as if the lips of the jet (into which the screwdriver goes) spread apart, they dig into the cast carb body and make removal even more difficult. If some gentle effort does not move the jet, flush the area thoroughly with air/soapy water to remove gasoline and apply heat to the brass jet with a small torch tip until a green glow is seen. Let it cool and it will turn out.
Wayne in Tn.
09-23-2004 05:07:56
J Bennet, That is a common question on those tractors. Requiring the use of the choke means it"s starving for gas. Start at the tank, by removing the gas line, open the sediment bowl, see if you have a good stream of gas, if so remove the line at the carb, then remove the elbow fitting. There should be a small strainer in the fitting. If the problem is not found yet, remove the carb. for a cleaning and inspection at the needle and seat and float.
