JD 50 Trans Oil / Powershaft Oil
BillS
09-22-2004 22:01:25
I filled my trans case with the 4 1/2 gallons of 90w and it started coming out of the fill hole for the power shaft oil. Now I have 90w in the powershaft box where the manual says is supposed to be 10w. I would guess that there is a seal between the two that is bad? Is it going to be hard or expensive to fix? Will the 90w hurt anything in there? Thanks
John Van Valkenburgh
09-24-2004 17:08:26
 Re: JD 50 Trans Oil / Powershaft Oil in reply to BillS, 09-22-2004 22:01:25
Bill,
Earlier this Summer I did the very same thing you are going to have to do. It's not particularly expensive and it's not a particularly complicated procedure but the rockshaft housing has to come off and its pretty heavy and quite bulky.
Its heavy enough so that you would not want to lift it yourself, but once it's on the ground, one person can manage it okay.
Basically what you will be doing is taking the rockshaft housing off and replacing all the seals and gaskets you find. Now would be an excellent time to replace the Powr-Trol seals and gaskets. Its a common problem in these old tractors that the Powr-Trol oil leaks into the transmission and also won't hold a load up without slowly sinking.
Frank is correct in that the seal between the PTO and transmission is actually two seals placed back-to-back. The original seal I pulled out was one piece but the replacement is two seperate seals.
My John Deere dealer had all the seals and gaskets, although most of them had to be ordered. If you have not done so already, now is a good time to check out the John Deere online parts site.
The John Deere parts manual is very handy at times like this.
Drop me a reply to this post if you have any questions I might be able to help with.
John 1953 Model 50
F-I-T
09-23-2004 06:25:52
BillS:
Yes, there is a seal in there (in fact the replacement is two thin seals), and while it's not difficult to replace, it can be dirty, heavy work. You have to remove the large rear end cover that holds the Powr-Trol unit, so the whole assembly is pretty top heavy. If you have a hoist handy it is a good idea. I like to make a couple of dowels out of threaded rod to use to hold the gasket in place as I slide it all back together. That said, I have done this many times and always alone.
You do not want that gear lube in the PTO housing as it can and probably will eventually allow the expensive clutch facings to de-laminate.
Try a search this site for more information on the repair. It's been written and discussed many times in detail.
Frank
