4020 hydraulic problem
RICKY IN KY.
09-22-2004 17:18:42
I was hooking up my bush-hog this evening and my pump started making a knocking sound . I didn't have any power steering or lift, didn't check the brakes but sure I didn't , shut it off quickly didn't see any oil leakes waited 10 minutes started it up and everything worked fine , but still had some knocking in the pump area . Need some information please.
G-MAN
09-23-2004 04:49:15
 Re: 4020 hydraulic problem in reply to RICKY IN KY., 09-22-2004 17:18:42
First make sure that the system is full of the proper fluid, and consider changing the oil and filter if it hasn't been done in recent memory. If and while the oil is drained, remove and inspect the transmission sump screen that pre-filters the oil prior to it going to the transmission/charge pump. If all is okay there, then you can start to suspect a stroke control valve, although are still more tests in the book to be done. Removing and rebuilding the main pump should be the LAST thing you consider.
RICKY IN KY.
09-23-2004 17:20:23
 Re: 4020 hydraulic problem in reply to G-MAN, 09-23-2004 04:49:15
Hey , I come in from work this evening and everything worked fine . I got a diesel mechanic to look at it with me and we were kind of on the same track as you G-MAN ,I HADN'T CHANGED THE FILTERS IN a WHILE for some reason it come un-primed . It has always had a whining noise , It could be those splines on the shaft causing the problem . I want to thank you guys for your help . I' m on here every nite looking at everybody else's problems, but when it come your own its a differant story . THANKS AGIAN RICKY
Gerald J.
09-23-2004 17:50:08
 Re: 4020 hydraulic problem in reply to RICKY IN KY., 09-23-2004 17:20:23
On the pre side console 4020 (4010, 3010, and 3020 among others) there is a check valve in the transmission supposed to keep the front oil cooler and reservoir from draining when the transmission is not turning. Its deep inside and hard to replace. Inspection requires destroying it after removing the rock shaft assembly.
There is a JD service information about converting an elbow (right behind the hydraulic filter into a check valve.
I have a sketch and parts list for that conversion on my web page http://www.geraldj.networkiowa.com Look for 4020 on the home page.
Gerald J.
john nelson
09-22-2004 20:35:17
I have seen the stroke controll valve make a hammering noise. Usually if it is sticky there will be times when the steering is slow and the lift jerky as it raises.
john
jdat jared
09-22-2004 19:07:23
it sounds like you need to have your main hydraulic pump rebuilt. but first check your pump drive. check the coupler and the rubber studs. some times those can wear out and ruin the coupler. if those are ok, then you will have to pull the pump.
jdat jared
09-22-2004 19:04:14
jdat jared
09-22-2004 18:56:22
