60 rockshaft PTO housing
Mike w J
09-22-2004 11:39:28
Can I remove the rear housing without taking the live pto clutch asembly apart I am getting trans. grease in the pto and need to put in a seal
Mike M
09-22-2004 11:50:21
 Re: 60 rockshaft PTO housing in reply to Mike w J, 09-22-2004 11:39:28
Yes you can pull off that back assembly and then put in a new pto pump seal without pulling the whole pto clutch apart. You will have to pull off the pto pump to put in the seals but that is no big deal.Put the seals in lips faceing opposite each other and use some shallac on the pump cover to seal it.
