Sharps, as you know, it could take several books to completely answer your question, but heres just a very few very basic things I would do: Set wheels in close together,,,,, ,,set up drawbar as much as possible as high n close to tractor as legal and physically possible,,,,, ,,,,, install new points n gap properly,,,,, ,,,,, ,install new plugs and use wire core NOT carbon core suppressor type wires,,,,, ,,run the carbs load needle a tad on the rich side, you dont wanna starve for fuel at the end but you dont wanna be so overrich it fouls the plugs either,,,,, ,,,,, have plenty of fresh clean water free gas in the tank,,,,, ,,,use wheel weights etc to get her right up to the maximum permissible allowed weight,,,,, ,,,,, have front tires aired up tight,,,,, ,,have plenty air in rear tires so they dont squat down n buckle too badly,,,,, ,,,,, consider disconnecting the Generator when pulling cuz it uses up some precious horsepower,,,,, ,,,,,if its a tight track you will prob have to use 1st gear (some pulls require it) but if she has enough power (I doubt it) and the track is dug up n dry n loose, you may do better in second??? Try n choose a path in the track thats not all dug up,,,,, ,,keep her wide open after the start and drive straight n be ready on the brakes at the end in case one wheel begins to spin,,,,, ,,BE SURE THE CLUTCH IS ADJUSTED ON THE TIGHT END you dont want it to slip !!!!! !!!!! !! Take 2 aspirins n call me Monday at the Office Good luck n God Bless John T
