2010 No clutch
donald
09-22-2004 08:28:31
I resently replaced oil seal on power drive shaft on transmission stopped the leak but upon reassembly no clutch dont understand. Clutch pedal very weak now and acts like its not engaging when you try to put into gear engine loads up almost stalls.Were did I go wrong Thanks
Britt
09-22-2004 15:41:43
 Re: 2010 No clutch in reply to donald, 09-22-2004 08:28:31
1. Possibly put the clutch disc in backwards.
2. The throw-out bearing carrier has turned and is not properly engaged by the throw-out fork.
I would vote for # 2.
Good Luck,
Britt
