Hard start/rough running 1951 B
Steve and Taylo
09-22-2004 06:33:06
Used the old girl monday night to pull some trees. Tuesday night I put some gas in her and now she barks and bellers, pops and backfires. Suspect dirt, however my gas barrel is filtered that I pump from, with a water trap. The tank on the B has been restored , cleaned and coated. I dumped the sediment bowl and there really wasn"t anything in it to speak of. Have a good flow from the drain cock on carb. Also have about 20 hours on new points, condenser and plugs.Any suggestions?
BushogPapa
09-23-2004 08:52:03
 Re: Hard start/rough running 1951 B in reply to Steve and Taylor, 09-22-2004 06:33:06
Never over-look the possabillity of moisture in the mag... You did use it the day before, and might have just got it warm enough to drive moisture up into the mag, but not got it hot enough to drive all the moisture out of it... It never hurts to open the mag up, and let the sun dry it out if you are not positive..
Carl
09-22-2004 12:51:03
Was the rubbing block on the new points lubed when they were installed? If not the block may have worn and let the point gap close up.
John T
09-22-2004 11:23:44
Steve n Taylor, that good gas flow out the carbs drain cock sounds like the tanks outlet n sediment bowl n the carbs side inlet strainer n needle n seat are all okay, which leaves still maybe a float problem or an ignition problem. Would choking help when that happens?? If so, then Im wondering about the float level or an internal carb blockage. The choke plate is tight n stays put on the shaft right??? Is she throwing a lot of black smoke out the stack when this happens???? If so the choke may be going closed or theres an air inlet restriction in the air cleaner or bowl or screen etc.
Even though they are fairly new, the first thing I would try is a fresh set of plugs, especially if they are blackend up badly. You might wanna check to be sure the points gap hasnt slipped and they are not burned or pitted or heavy oxide coated while youre in there. Also be sure the condensors in tight n wired and theres no shorted wires to it. If its a battery powered coil ignition, the switch may be bad, try to hot wire the coil n see how she runs??? Remove the plugs but have the wires attached and the sides grounded n crank her over to insure BOTH plugs yield a good visible blue spark??? If not, let me know what ignition you have and look at the points n cap n rotor etc plus the wire condition. If it just acts up when she gets hot, it could be a condensor or coil problem.
As best possible you gotta figure out if its a fuel or ignition problem, or if its fuel is it too much (black smoke, maybe float problem or choke problem) or too little (choking helps). if the fuel is okay my best guess is try new plugs, check the spark quality, points n the gap n wires, take 2 aspirins n call me monday at the Office.
Lemme know, Good Luck n God Bless
John T
Steve and Taylor
09-22-2004 13:20:44
 Re: Hard start/rough running 1951 B in reply to John T, 09-22-2004 11:23:44
Thanks John for the input. Yes, choking does help. I can get her started, but have to keep choke partially pulled out to keep it running. I really suspect the carb got something in it. I'm about to pull it off and run a wire through every little hole I can find. It just seems suspicious that it acted up right after pumping gas into it.
Steve
John T
09-22-2004 15:38:18
 Re: Hard start/rough running 1951 B in reply to Steve and Taylor, 09-22-2004 13:20:44
Since we now know choking helps, its sounding more like fuel restriction and/or a carb than an ignition problem, I agree with ya. Still, if gas flows out the bototm carb bowl drain cock well, the tank outlet n sediment bowl n lines n side inlet strainer n needle n seat flow seems good, leaving maybe a low float problem or another internal carb restriction. Good luck, let us know.
John T
