1952 60 Trans rearend oil capacities help
Tim H
09-21-2004 16:08:59
Hey guys, I need to know how much engine,transmission and rearend oil to buy and in what weights. Manual is on the way just hasn't made it yet.
TIA
Tim
Steve JD60
09-21-2004 19:21:04
 Re: 1952 60 Trans rearend oil capacities help in reply to Tim H, 09-21-2004 16:08:59
Engine capacity is 8 quarts. Straight 30 weight is recommended for summer or 10wt for winter, but I'm using 15w40 in mine right now.
Transmission and rearend oil is all the same with capacity of 24 quarts. Recommendation is for 80 or 90 wt. There is the first reduction gear case on right side of the tractor that holds 1.5 quarts of the same oil and has a seperate drain and fill plug. Fill plug is on top, just behind the pully.
The power take off housing is seperate and should hold 2.25 quarts of 10wt oil. Hope this helps.
Tim H
09-22-2004 15:38:50
 Re: 1952 60 Trans rearend oil capacities help in reply to Steve JD60, 09-21-2004 19:21:04
Thanks Steve.
Tim
