Carb on G
farmallman
09-21-2004 15:34:42
What kind of carb would be on a JD "G" s/n 17016? Thanks
Pappy
09-21-2004 18:37:29
 Re: Carb on G in reply to farmallman, 09-21-2004 15:34:42
I believe all "G" tractors are all-fuel.
John T
09-21-2004 15:54:15
Man, the book I have from Roberts (Sorry, no Warranty) shows that the JD Model G with Serial Numbers G13,000 and up, used the Marvel-Schebler DLTX-51 Gasoline Carb. If that information is corect, thats referred to as the Big Nut Carb as it has that large bottom brass bowl nut. Im unsure of the All Fuel carb numbers, the same book shows the early G"s (G1001 to G12999) used the DLTX-24 and DLTX-38 All Fuel carbs.
John T
farmallman
09-21-2004 16:00:30
 Re: Carb on G in reply to John T, 09-21-2004 15:54:15
Thanks. My carb had a big nut on it so i think it is correct.
