29 D Pulley, roller bearing race was shimmed, good
Bruce Klawiter
09-21-2004 12:35:24
Have a 1929 �D� #75049. Took off the belt pulley and noticed I could turn the race for the roller bearing in the housing. After taking the race out I discovered the race had been shimmed, also the housing the race is to press into has been pick punched with a screw driver? In an attempt to make the ID smaller.
It appears to have come form the factory this way as I can still see the machine marks and the ID is the same the entire length of the bore even where the felt dust shield and retainer are.
Do I put it together the same way? Does the race need to be a press fit? Hoping I can find a cheaper way to make it fit than chroming the OD of the race and having it ground to size.
Your help well be greatly appreciated.
Bruce
