A Frame
Deereman
02-05-2004 14:23:21
third party image
Why did only 1944 A JDs have this type of frame. It seems like this frame would be stonger. Most of the pressed steel frames always crack.
Greg F
02-06-2004 06:59:20
 Re: A Frame in reply to Deereman, 02-05-2004 14:23:21
Deereman,
Very nice tractor. You think you could email me some close ups of the engine area. My 41A is missing the 3 way fuel valve and I would like a good example of how it should be. Your tractor is perfect. I know it is a lot to ask. If you can and have the time my email is [email protected]
Thanks
Greg
Will P
02-05-2004 15:45:56
I saw the picture you posted the other day. Nice A. I specialize in "war" models. I have a 43A and 43B. The B had that cast frame for 43 and 44. The A got that frame mid year 43 and all of 44. So it is not only 44 as you state. Also, you have a non pressure cap on your A, which tells me that your A either had it radiator top tank changed, or your A is really a 43, not 44. For your tractor to have the cast frame and a non pressure cap. It would have to be in the serial range of 522600-523599 Which would put your A in the 1943 model year.
Will P
Wayne Swenson
02-05-2004 14:51:52
Would you believe there was a war going on and steel was in short supply??
