60 clutch theorey of Operation
Fred from MO
09-21-2004 03:15:08
I reciently have tore my clutch and pulley down because the clutch was hanging up and not disengaging. I found that the back side of my Operating bolts were worn where they appeared to have been rubbing. One operating bolt was froze in the pulley and would not allow the one clutch dog to move. Fasignated by the clutch, I was wondering the theory of operation. When the operating lever is pushed forward to engage the clutch this in turn moves the clutch fork linked to the operating sleeve. The operating sleeve moves away (to the right) of the tractor, pushing the pulley, inner friction disk into the inside(or backside or LH side of the drive disk). Here is where I am unclear; This movement of the operating sleeve to the left also cocks the dogs down pivoting, drawing the operating bolts tighter. When the operating bolts get drawn tighter this hooks up the other disks on the (outside or RH side of the drive disk)?. Does this sound correct? Because I am curious. I am more used to an automobile style clutch and operation. I would like to understand where the "snap" feel is supposed to come from-the action in the dogs? Looking for a "professors" answere I guess.
Mike M
09-22-2004 07:09:50
 Re: 60 clutch theorey of Operation in reply to Fred from MO, 09-21-2004 03:15:08
You could have some expert go on and on explaining this in high tech terms, but I would rather read and agree with FIT 's words short and to the point.
Fred from MO
09-22-2004 19:13:40
 Re: 60 clutch theorey of Operation in reply to Mike M, 09-22-2004 07:09:50
Thanks for the affirmation Frank!! I wanted to make sure that I fixed what I thought was broke.
F-I-T
09-21-2004 14:26:40
Fred:
You got it right.
I am by no means a professor, and I hope the true experts chime in, but here's what little I can offer concerning the many cltuches I have had apart on Waterloo two cylinders.
The snap comes when the operating sleeve pushes the dogs over center and that locks the clutch pack together. The taughtness of the clutch pack is the result of the tightenss of the three operating bolts.
Frank
