Ignition Points - Setting
Don
02-05-2004 14:21:27
I have a 1948 JD B, with a Delco Remy distributor.
What is the specified setting for the ignition points for this tractor, with the above distributor? My book only covers the Wico distributor for a B. Thank you for your help.
John T
02-05-2004 17:26:25
 Re: Ignition Points - Setting in reply to Don, 02-05-2004 14:21:27
Don, As Clooney posted, while 0.022 is the normal gap setting, if the shaft bushings are worn or youre experiencing any problems, you may try settign the gap at slightly wider than the 0.022 and see how she performs. A timing light can also indicate performance at rpm plus any unevenness or irregularities.
Good Luck n God Bless, post back or e mail [email protected] any questions
John T
Clooney
02-05-2004 14:43:25
Don, the round body Delco distributors used .022" points gap on the high point of the distributor cam.
[email protected]
Don
02-05-2004 15:23:27
 Re: Re: Ignition Points - Setting in reply to Clooney , 02-05-2004 14:43:25
Thanks Clooney. I appreciate your help.
