JD 2640 trans cover
Cory
09-20-2004 16:51:52
My 2640 has the double jointed shifter for hi lo reverse. Will a straight shifter (later models) work to replace this one? The cover is messed up, the shifter won"t stay in, retaining ring groove is worn away with some broke off. I tried the JD retaining kit but with out the whole groove, the retaining rings just pop out. I can get the straight shifter cover, I just need to know if it will interchange.
Dieselrider
09-21-2004 04:41:49
 Re: JD 2640 trans cover in reply to Cory, 09-20-2004 16:51:52
Cory, I don't know if the other cover will work or not but, what I did to correct the problem was this. I machined off the top part of the cover where the shifter goes into and made a ring that fit over it out of steel. Then drilled three or four holes and tapped for small cocket head machine screws to hold it on. I have a machine shop here so for me it was no problem to do this. I don't know what you may run into. Any good local machine shop should be able to help you out far cheaper than a new cover(if they are still available). JD should not have used an aluminum cover in that situation. It's way too soft. Let me know how you make out.
Dieselrider
09-21-2004 06:02:01
 Re: JD 2640 trans cover photo in reply to Dieselrider, 09-21-2004 04:41:49
third party image
Cory, Here is a photo I posted in "stuck and troubled" section of the board. It's not very clear but it should give you a general idea of the finished project. If you have any questions e-mail me at [email protected] I have more photos and can always take more if you need them.
