Clooney or Anyone
Bets
09-20-2004 16:45:38
Clooney what do you recommend for sealant on manifold studs that protrud into the coolant. There is some play in the threads so I am concerned with it leaking. Also what are the torque specs for the head and rod bolts. Its on an unstyled A with heisler head. I am having the cam ground to stock specs and installing new valves. Do you recommend putting in new valve springs? I am going to have to bore the block as there is some pitting in one cylinder. It had the standard cast pistons in it and was stuck. Would you put aluminum pistons back in it or try to find used 90 over cast pistons. It is going to require boring 90 over to clean it up. The 90 over cast pistons are about impossible to find so I was leaning toward aluminum. thanks in advance Bets
Greg S
09-21-2004 18:07:46
 Re: Clooney or Anyone in reply to Bets, 09-20-2004 16:45:38
A while ago I had seen where Clooney (?) had recommended using Permatex 3D for the head gasket. Since there was lots left over, I used it in other places such as the threads you are talking about. Worked fine.
Will P
09-20-2004 20:35:11
Deere only made standard and .045 over. No bigger that I know for the letter series.
Will P
Britt
09-20-2004 19:38:51
You could sleeve the block and then use standard size pistons. There are several locations that can sleeve a John Deere block. One is located in Goreville, Southern Illinois. Their phone number is 618-995-2296. I know that they can handle 720/730 blocks so your "A" should be no problem.
Good Luck with your "A"
Britt
Earl S.
09-20-2004 18:39:37
Bets, you might try Jerry Hinrichs 815-778-1900 .He sells pistons and can tell you what you need. Earl
