316 mower deck prob
scooter
09-20-2004 16:42:54
hey i got a 316 with a 42 in deck and the 3 blades on the deck keep cutting a dif hights can someone tell me the prob if so how do i fix it
Maark
09-21-2004 10:42:46
 Re: 316 mower deck prob in reply to scooter, 09-20-2004 16:42:54
Sometimes the deck where the bearing spindle housing is bolted can be bent where the bolts go through. Usually happens when hitting a solid object. Take your deck off, turn it upside down and measure from the blade tips to the deck and you can tell which one is bent. Just remove the spindle housing if thats's the problem and straighten the deck with a big hammer.
johndeereal
09-20-2004 17:34:41
You may have one or more bent blades, badly worn spindle or foriegn material between the blade and the spindle. Remove the deck from the tractor and turn it over (on saw horses is good). Carefully rotate the blades and make sure they align.
