JD 510 Backhoe Low Hydraulic Pressure
Stanley Kelembe
09-20-2004 12:26:12
Cant get decent pressure on backhoe and nothing on loader.Replaced all filters removed and cleaned screen.Transmission works OK.Steering sluggish and no movement of loader at all.I just overhauled engine and new injection pump.After getting motor running I had very slow movement of loader.Now nothing.Machine sat for 3 years outdoors. No water in tranny.Perhaps valve someplace stuck?Shure would like to get it usable as starting to have a small fortune invested in it.Any help is grateful.Stan
Jonathan in MA
09-20-2004 17:54:56
 Re: JD 510 Backhoe Low Hydraulic Pressure in reply to Stanley Kelember, 09-20-2004 12:26:12
If there was a lot of debris in the filters , its also probably in the stroke control valve on the front pump ..Does this have a double pump on the front (2 pumps mounted piggy-back ?) or does it have a front pump and a mid-mount pump underneath ?? First I would remove the de-stroke solenoid and check if its partially stuck open. There is a plug available that eliminates it-- if you are close by and friendly with any JD mechanics, they probably have one or 2 in their toolbox. Then you can try capping the pressure port coming out of the pump (closed-center system so yes --you can cap the pressure port) Install a guage in the pump to make sure the pressure is still low. It should be 2300-2400psi..This test would eliminate the possibilty of the pump feeding an internal leak in the sysytem, and not being able to build pressure..Not likely though as it would have to be a large internal leak !!...Then I would remove a piston or 2 or 3 to see what they look like. They are behind the plugs screwed into the pumps circumference...hence the name "radial piston pump"..They should be smooth and have a flat face and be tight in their bores..no side slop..If they look ok, then I guess you should remove the pump and remove the stroke control valve(its the end-cover on the pump) there are valves and a screen in there that usually cause the problem..as well as some orings that get "petrified" with age..a JD manual would be handy when rebuilding the pump..Sometimes the guts of the stroke control valve can be removed in place..but be careful not to lose anything..a parts pic or tech manual pic should be used so you know what to expect when you remove the plug fittings.
