JD 1020 problems
Gene Smith
09-20-2004 11:34:51
We have a 1973 JD 1020 gas 3 cylinder tractor giving us fits. Initially, it would run fine until it got warmed up, then sputter and backfire and then refuse to run.
We cleaned the carburetor, put in new plugs, new fuel filter, drained all gas and blew out all gas lines. Distributor looks fine. JD dealer suggested a new coil, which we installed and then it would not run at all. Seems like everything we try makes things worse rather than better.
We would certainly appreciate any wisdom you could share with us on the matter.
Thanks
Gene Smith
mowr
09-20-2004 18:58:55
 Re: JD 1020 problems in reply to Gene Smith, 09-20-2004 11:34:51
Does it have an anti-dieseling solenoid on the carburetor and if so, is it working properly?
Gene Smith
09-21-2004 11:45:34
 Re: JD 1020 problems in reply to mowr, 09-20-2004 18:58:55
No, the carburetor does not have the solenoid. It seems pretty basic, and I've cleaned all of the parts.
mowr
09-23-2004 20:13:08
 Re: JD 1020 problems in reply to Gene Smith, 09-21-2004 11:45:34
Condenser sometimes. An inexpensive fix if that's it. Let us know.
