420C brake and clutch
michael solan
09-20-2004 07:51:05
Hello, I bought a ROUGH 420crawler with JD 90 loader....The clutch and brake pedals are locked together...As I depress one, the other engages as well. Is this as it should be with the 420 crawler with loader? I know they work independent of each other on the MC and 40 and the 420 with blade..... ...Any suggestions? ANYBODY? Thanks, Michael Solan...Phone...814 692 8291
CPeter
09-20-2004 15:47:42
 Re: 420C brake and clutch in reply to michael solan, 09-20-2004 07:51:05
Been there, done that, got the Tee Shirt!!. You may be real lucky and get them to come apart, but probably you are going to have to split the tractor at the transmission/center frame and put the heat wrench to the shaft inside the center frame housing. First, however, try PB Blaster and if you take the right pedal off, "GENTLY" tap on the shaft, you may get it to move towards the left side. Put the "Blaster to it and work it back and forth. When you get it free, see if you can work in some grease. There is a pin holding the right pedal to the shaft.
CPeter
Hwarrior23
09-20-2004 09:01:26
The pedals on both sides are both clutch pedals. The two steering arms act to disengage the cutting clutches and engage the brake band.
ralph oregon
09-20-2004 10:56:49
 Re: 420C brake and clutch in reply to Hwarrior23, 09-20-2004 09:01:26
the pedal on the left is the clutch and the right one is the brake. as the shafts go though the clutch housing one inside the other that is where it is frozen and most likly needs to come apart to fix. ralph
Henry J
09-20-2004 08:42:50
Mike
That is common on bone yard 420'S. Check where the pedal shafts are, I bet one pedal has a shaft that goes through the pivot on the other pedal and it is rusted tight.
