J ohn Deere G Power shaft
JD Jerry
09-20-2004 05:39:04
I just brought my G home and took off the loader. The pto pump was welded to the shaft.It has a large pto shaft. Do all G's have a large pto shaft?
JD Jerry
09-20-2004 13:01:39
 Re: J ohn Deere G Power shaft in reply to JD Jerry, 09-20-2004 05:39:04
I did some research and found out the later ones had a 1 3/8 shaft. As I need a different one I might as well look for the standard shaft. Thanks for the input.
Deere John 2004
09-20-2004 07:34:04
"G"s were made before PTO dimensions were standardized. As far as I know, all "G"s were manufactured with 1 5/8" PTOs, oversized. Deere may have maufactured a retrofit PTO shaft that made it 1 3/8" (they did for the "B"s making them 1 3/8" rather than the 1 1/8" they came out with). However, most people purchased an adapter, stub shaft(still available) that went over the the 1 5/8" to convert it to 1 3/8". The stub shaft made the PTO about 4-5" longer and caused some problems when running heavy PTO equipment. Back when Our "G" was our main trcator, we made an extention for the Drawbar that was the same length as the added length of the stub shaft to keep the PTO geometry correct.
Will P
09-20-2004 20:37:53
 Re: J ohn Deere G Power shaft in reply to Deere John 2004, 09-20-2004 07:34:04
The last year or two had 1 3/8"
Will P
Hayfarmer
09-20-2004 07:27:08
The older Gs had the large pto shaft as it was believed they needed a bigger shaft to handle the power. I am not sure at what point it was changed to the smaller shaft. I have a pto adapter for my 38 G to go from the 1 3/4 to 1 2/8 standard
