4010 Remote Valves
Rex
09-20-2004 05:21:20
I had the RCV assembly worked on, but the valves still don't work right. One continues to build pressure and the loader arms keep going up slowly and the other lets pressure off and the bucket keeps going down slowly. I have been told that the valves are worn and need to be replaced. I guess I can look for used parts, but I am wondering if the valves can be refurbished.
matthies
09-20-2004 20:46:26
 Re: 4010 Remote Valves in reply to Rex, 09-20-2004 05:21:20
Do what msb said, and have the rebuilder check them with air. Plumb the valve right to shop air and check. Fought a pair of these until I hooked air to them. The little relief valve in the end cover gives problems too.
msb
09-20-2004 08:25:36
Those SCV valves can be a bit tricky to adjust.The seats can also be reground if you have the right special tool.Sounds like you need to take it back and let the rebuilder lick it over.On some rare occasions,I have seen some with internal cracks that can't be repaired without replacing the housing.
