Electric Destroke Solenoid Main Hydraulic Pump
Stanley Kelembe
09-20-2004 02:51:54
Need information on the destroke solenoid mounted on main hydraulic pump on a 510 backhoe.Mine is not hooked up just a 2 wire connector hanging in the breeze.Wiring diagram shows it hooked up to starter relay.Is it only active when starting to relieve load on starter?Is it needed otherwise?Does it affect output of pump? Stan
Bob
09-20-2004 06:19:33
 Re: Electric Destroke Solenoid Main Hydraulic Pump in reply to Stanley Kelember, 09-20-2004 02:51:54
The solenoid connects to ground, and the starter relay. When energized it destrokes the pump for faster cranking.
If it is not hooked up, and the engine is cranking and starting well, don't worry about it, as it is not affecting the pump operation when unhooked.
