40 Gas and Radiator Cap
krk
09-19-2004 18:17:16
I am restoring a John Deere 40 and I would like to know what the part numbers are for the Gas Cap and the Radiator Cap. In the pictures in my owners manual both look the same size and shape. When I went to buy a Gas cap they tried to sell me a cap that looked like I could perculate coffee with it. Does anyone know if the caps originally were the same? or is there a diffence? It appears that it the design was changed after some lawyers found a way to make money.
Maark
09-20-2004 11:25:55
 Re: 40 Gas and Radiator Cap in reply to krk, 09-19-2004 18:17:16
The original gas cap does look like it can percolate coffee, while the radiator cap is a flat design,3 1/4'' in diameter. They were both cadmium plated {silver} from the factory and never painted. I did alot of research on mine when it was restored this last winter.
CMB
09-20-2004 10:04:30
I've had a "40U" since 1965, & the caps are definatly different. The radiator cap is larger on the OD & has no vent, while the gas cap is smaller & vented, however without checking, I can't say for sure that the locking system is different.
andrewk
09-19-2004 20:53:25
best place I've found is sharps online I got both rad and gas cap for my M and 420 from them. My local JD dealer actually gave me a tip to check with them first on such items . I think the web site is Link
krk
09-19-2004 20:59:28
 Re: 40 Gas and Radiator Cap in reply to andrewk, 09-19-2004 20:53:25
Still want to know if the original Gas cap and radiator cap were the same cap at one time.
CLW
09-20-2004 09:38:51
 Re: 40 Gas and Radiator Cap in reply to krk, 09-19-2004 20:59:28
krk, my parts CD says the Rad. cap is AL2275T with no Sub. The gas cap is AM3892T (Sub AM2307T) So don't look like they were.
CLW
Mike M
09-20-2004 04:51:47
I think originally they were. The gas caps have been changed to one with a vent and a pressure relief much like the ones Farmall came out with in a campaign 20 yrs ago they gave you one for free to keep you from getting burnt when hot pressureized gas sprayed on you if you opened the cap when hot.
