720D service manual
CFWelles
09-19-2004 13:36:36
I have an opportunity to buy a very nice 720D original service manual. I have recently entered into a contract to purchase a 730D. Is this manual accurate for just about everything on the 730? Also, the tractor I am in contract on is an ES. Didn't I see that ES was available as well on 720's, late 720's? Appreciate some comments. Also if you fellows feel that some of the aftermarket manuals are good service guides I would like to know this. Also, does anyone know the factory published delivery weight on a 730D ES row crop with WFE?
720Deere
09-19-2004 15:35:16
 Re: 720D service manual in reply to CFWelles, 09-19-2004 13:36:36
The 720 manual (SM2020) covers the 730 also. As far as published weights go, don't waste your time going by that. A 720 ES with wide front end will weigh about 8000 lbs with a tank of fuel and 3 point hitch. That is with no fluid in the tires. If tires are ballasted, that could add up to 1800 more lbs for a 16.9x38 tire. 15.5 tire ballast should weigh less than 1500 lbs. My 720 pony start with rollomatic weighs right @ 8000 lbs with no ballast also. After filling the tires with plain old H2O, it weighs 9580 lbs. Shipping weight is just that, what the tractor weighed at the factory with no oil, water or fuel. I have never seen a tractor that actually weighed <= it's published shipping weight.
Soldier Tom
09-19-2004 13:55:13
Mine is a reprinted one not an original, but my 720D service manual (SM2020 Dec'57) shows a 720 d shipping at 7,415 lbs with an adj w/f and 7,790 on a standard. Can't find anything about electric cranking motors in this one, except the one that starts the Pony motor. So you might want to check on the contents before you buy it, if you are looking for electric cranking motor specific stuff. I bet there is a book from Deere that talks about that tho, check this site in the tractor manuals section.
If you don't take the manual, I'd like to talk to the fella about it, especially if it is an original and not reprinted from an original. Just think it would be neat to have.
~Walk in peace~
Soldier Tom
CFWelles
09-19-2004 17:45:58
 Re: 720D service manual in reply to Soldier Tom, 09-19-2004 13:55:13
Thanks fellows. Appreciated your comments. 720, your weight of 8000 corresponds to what I have been told about the machine I have under contract. Fellow says about 8500, but tractor has four approx 140 lb. rear wheel weights attached. (No loaded tires)
