JD 50 Clutch
BillS
09-19-2004 09:31:55
The clutch on my 50 is REALLY grabby. I have another old 50 and it is the same way. Is this just the nature of the beast or does someone have some ideas of what I might need to do?
Thanks!
John Van Valkenburgh
09-20-2004 18:32:13
 Re: JD 50 Clutch in reply to BillS, 09-19-2004 09:31:55
Bill,
The clutch on my 50 can be a little touchy at times. Seems to be more pronounced when in the lower gears. Sends the front end skyward, much to my discomfort.
I think it may be partly a sign of an "unevenly" adjusted clutch or perhaps a little oil residue on the wearing surfaces.
My clutch does not always grab. I've also noticed that sometimes I have to pull back a couple of times to get it to snap back out. Overall I attribute that to worn toggles. A clutch rebuild is on my list of projects this Winter.
John
1953 Model 50
Bob K
09-20-2004 14:05:27
My 50's clutch is pretty sensitive too. I use two fingers on the clutch lever to engage it -- almost like trying to balance a broomstick. I agree with John that the 50s seem to just be that way.
John Hicks
09-19-2004 18:56:30
This is just my 2 cents. Most 50's are that way. I went around and around with mine. I did get an idea that did work for me. I bought an inch pound torc wrench and very carefully set the adjusment using the torc wrench in order that each adjusting nut was tightened the same. This did work for me.
