1949 John Deere A . Too much fuel.
Mark DeGroot
09-18-2004 17:58:37
Just rebuilt carb and tried to start. Raw fuel is flooding engine in what seems to be unusual volume. Manifold has a half inch rusted out hole in it. Where can I find a restoration quality used manifold (ser # 622797). Tractor has spark but refuses to fire. Much of the raw fuel comes out of manifold rust hole and some comes out compression release petcocks under engine. Help!!
Mark DeGroot
09-20-2004 05:22:01
 Re: 1949 John Deere A . Too much fuel. in reply to Mark DeGroot, 09-18-2004 17:58:37
Got it started. Thanks!! Took off the oil bath air filter and found it full of oil and water. Drained it. Pulled the tractor in gear with no plugs until all misting stopped. Reinstalled plugs and it started. One side has only 30 lbs of compression, the other 90 but both sides fired. Still need to find a manifold. Very much appreciate this forum and your help. MD
John T
09-19-2004 09:53:14
Mark, sounds like she may be refusing to fire due to all the excess raw gas wet fouling the plugs?? Did you set the float level to where she shut off the needle n seat flow when she was about level??? If you remove the carb air intake piping with the gas on, is gas flooding up into the carb??? If so its still a float or needle n seat problem or misadjustment despite the carb rebuild.
If the plugs have been badly fouled I would start with a fresh set and not too much choking (check to see if float n needle n seat are working) and give her a try. You might wanna insure the choke butterfly plate is opening fully and stays put where you adjust it and that theres no air inlet restrictions in the air cleaner or intake air piping. Have you adjusted the carbs needles n that make much difference??
You may just have a speck of dirt in the needle n seat or the float not adjusted, try the easy simple things first like the float system is working then a fresh set of plugs and make sure theres no inlet air or choke restrictions n see what happens. Be sure theres not a bunch of gas that got into the oil already, if so find the cause n drain n refill of course !!!!! !!!!!
Let us know, Good luck n God Bless
John T
Pappy
09-18-2004 22:48:40
My "A" did the same thing when I first got it. (flooding). The carburetor float had a crack in it and it wouldn't float. New float solved the problem and I repaired the old one for a spare.
F-I-T
09-18-2004 18:15:51
Mark:
How is the float setting? How is the needle tip? Is the hole on the exhaust side? I would doubt that she'll start and if so run at all right if that hole were in the intake side.
Frank
