problem on 34 A
Big Jake
09-18-2004 16:09:03
I was messing with a 1934 A and thought I had flooded it out so I was tired of spinning the flywheel and pulled it off with my 60 when I went to start the A it rolled over about three times and back fired and then started But it would not run correctly and it got hot so hot that when i pulled into the shop that the manifold was cherry red after only running 5 minutes. Can any one give me any way to go I'm thinking a head gasket or maybe the inside of the manifold came apart any help would be aprecated
easydoesit
09-20-2004 08:31:15
 Re: problem on 34 A in reply to Big Jake , 09-18-2004 16:09:03
Big Jake, had same problem on my G. Exhaust valve wasn't sealing and burning gas in the exhaust manifold. Make it cherry red pretty fast. Could be chunk of carbon in valve seat or sticking due to not getting lubed at valve cover. Easy
Pappy
09-18-2004 22:52:41
Start here: Check the ignition timing Check the valve tappet clearances
The hot manifold would indicate a timing problem to me.
big jake
09-19-2004 13:48:46
 Re: problem on 34 A in reply to Pappy, 09-18-2004 22:52:41
the tractor was running fine earler in the day. then when I tryed to start it,it wouldn't start the only thing that I had done was clean the points to be sure I was getting good contact then I pulled it off and it back fired and started heating .
Ken C.
09-18-2004 21:27:15
I wish i could help you out, but i have a 36 that seems to have the same problem. Can't crank it by hand, floods bad, gas drips out the manifold after a while but never hits unless you pull it off. Get it running and set carb,the next time you crank it you have to reset the carb again. Maybe someone can help out, Ken.
