JD pump engine
BSer
09-18-2004 13:10:40
I have a 3 cylinder JD engine on a hydraulic unit of unknown age.I need to rebuild it and want aftermarket parts. The first question is what's the tractor? Can anyone tell me the Agricultural application of a 3179df my serial# is CD3179D856025 that is block casting # R89834 Any sources of aftermarket parts is appreciated. Thanks!
Allan/CA
09-19-2004 10:09:26
 Re: JD pump engine in reply to BSer, 09-18-2004 13:10:40
The 179 motor is still being used on many current and past models 5210,5220, 2255, 2155, 240 skid steer and many turbo models. The motor can also be used as a replacement engine for the 152 and 164 equipted tractors, such as 1020 or 1520 models.
F-I-T
09-18-2004 13:29:04
BSer:
You might try Don's Diesel. They sell after market kits. They show a 3/179 cu.in. Deere engine as used in the 2040/2240/2250 tractors.
2040-2240-2250 FP#22 179D/179DT cu.in. diesel &/OR turbo german diesel/ 3 cyl $ 495.00 Full gasket set - $155.00 Head set and pan gasket - $55.00
