310 A transmission
Jarrett Lambert
09-18-2004 12:41:52
I have a mid-70s 310 backhoe, which is I believe is an A. The hoe and the bucket work great; strong and fast, but the transmission is weak and sometimes slips in 3 low while on a hill. Tractor will stall or barely move on level ground in high gear. I mounted a gauge on transmission as per the directions shown in the service manual. The pressure was consitant @ 65psi. Much lower than. recommended. I attemped to shim, but I was unable to add more than the 5 shims already in place. My question is, are there other filters or screens which could be causing the problem specific to the transmission? Thanks J. Lambert
david val
09-19-2004 07:17:22
 Re: 310 A transmission in reply to Jarrett Lambert, 09-18-2004 12:41:52
the clutch pressure is determained by the clutch pedal position. make sure that the pedal, and with it the shaft on the reverser control valve are moving all the way back by the big spring. adjust with the aid of the gauge to get about 140 psi.
david
Roy Suomi
09-18-2004 21:15:47
With a gauge in reverser presure port , if both fwd and rev are same presure or close try this..Run engine at low rpm. Is pres.real low ?Speed up engine while watching gauge, does gauge pick up pres.? If so, the filter bypass valve probably has a small chip of junk in it holding it partially open. Pull off vertical hydraulic filter. If you look up into the filter bore of transmission you will see a small spool in the case. There is a plug on the side of trans housing that lines up with the spool. Take out that plug and using a screw driver carefully pry out the spool. Pull out the spool and check if the valve inside the spool is free to seat or is it held open slightly. It doesn't take but a tiny chunk of debris to foul up that valve..
Jonathan in MA
09-18-2004 19:45:33
Is it the same in reverse ?? does it slip etc ?? If it slips in forward but not reverse, then the tractor has to be split and there is a clutch pack and seals that have to be replaced/repaired...if it does it in forward and reverse, then it usually is just a linkage adjustment which is essentially adjusting the clutch engagement pressure....
