4020 battery cable placement
Doug Chesnutt
09-17-2004 19:50:04
JUST BOUGHT THIS TRACTOR FROM AN ESTATE NEAR MY PLACE.the problem is that I am not to well versed on any thing over 2cyl.THE BATTERIES WERE OUT OF THE BOXES WITH THE CABLES DANGLING,THE SN T213P
125768R Has a 24v starter,and an after market altinato cannot tell what voltage it is ,that is not hooked up.is this a positive
or neg. ground system ? sure could use schematic
on how to hookup the cables to the battery.With out the engine running I cannot move it or even load it to get it home.
Thank's ahead of time Doug C Tx
Pete/ME
09-19-2004 03:05:35
 Re: 4020 battery cable placement in reply to Doug Chesnutt, 09-17-2004 19:50:04
I can't tell from the ser. no. if your 4020 is a PowerShift or Syncro. If it's PowerShift you don't want to be towing it without depressing the tow lever. The thing might have been in the process of being converted to 12v. from 24v. If it were me, I'd have somebody who knows his beans take a look at it.
Bob
09-19-2004 08:41:22
 Re: 4020 battery cable placement in reply to Pete/ME, 09-19-2004 03:05:35
And, if it's a synchro you sure don't want to tow it unless you are sure you have the tranny shifter in the elusive "TOW" position. At any other position of the shifter, gears will be spinning on the stationary transmission top shaft with no oil, because the tranny pump is not turning. NOT PRETTY!
Gerald J.
09-18-2004 08:16:19
Its neither positive nor negative ground. The ground is between the two 12 volt batteries. One 12 volt system is positive grounded, and the other is negative grounded. Light and other loads are connected to both sides. Charger (probably not an alternator) and starter float.
Get thee an owner's manual and a simplified shop manual such as the one from I&T. Some of these questions will be explained as well as how to drive that transmission.
Gerald J.
thurlow
09-18-2004 05:58:16
If it has a 24v starter, it has a mechanical fuel shut-off..... if it were me, I would pull-start it and drive it onto my trailer; could loosen the fan belt if you're concerned about the alternator turning..... ..
