Flood Damaged Tractor
RickD
09-17-2004 17:23:41
Help! My brother was in the path of Hurricane Ivan. He moved his JD 850 to, what he thought, was high ground - it was not high enough. The flood water was over the top of the tractor. Of course, the water got inside the engine, etc. What is the procedure for repairing this water damage (Diesel engine)? This happened in Franklin, NC. Terrible flood damage all over that area of NC. Thanks much in advance.
G-MAN
09-18-2004 04:37:00
 Re: Flood Damaged Tractor in reply to RickD, 09-17-2004 17:23:41
Here's Mother Deere's procedure that I posted earlier and as mentioned by F-I-T:
Problem:
Water damage causing rust and dirt or silt contamination.
Solution:
The procedures listed below should be considered where possible:
1. Do not attempt to start tractor as water in the cylinder(s) will cause hydraulic lock, which may result in major engine damage. Also, contaminated oil will be circulated throughout the hydraulic and transmission systems. If the tractor must be moved to perform a cleanup, place the transmission in tow and haul by truck.
2. The engine should be completely disassembled, inspected for damage and thoroughly cleaned. Tractor works service information bulletin r79-20-11 should be referenced for cleaning procedures. Oil coolers, intercoolers, rocker arms and shafts, turbo chargers and injection pumps are assemblies on which additional cleaning efforts need to be applied in order to assure future reliability. Any parts which exhibit rust must be replaced. All seals, gaskets, etc., must be replaced.
3. Drain the transmission case, clutch housing, final drives, and front axle compartments where applicable. Flush transmission with procedure outlined in the technical manual under hydraulic repair, using an oil transfer pump. Remove the transmission pump inlet screen to facilitate removal of debris. Do not reuse oil drained from compartments. When compartments are drained, flush as soon as possible and refill with clean oil. If compartments are drained and left empty, rust and corrosion will form. After flushing, circulate hot air throughout case if possible; try to dry any moisture remaining on components.
4. Remove any drain lines to the transmission sump to see if water is present (such as drain from main hydraulic pump, selective control valves, etc.). If water is present, the component should be disassembled and thoroughly cleaned.
5. Drain and flush the fuel tank. Dry completely before refilling.
6. Replace all hydraulic, fuel and air filters. Lube all grease zerks sufficiently to flush water and debris. Repack front wheel bearings on 2wd tractors. If applicable, install grease fittings and lube to flush water and debris from axle outer bearings.
7. Clean external debris from radiator, oil cooler, condenser, exhaust system, intake system and from all external control linkages, etc.
8. Flush the air conditioner compressor clutch with clean water.
9. On most models with sound gard body, the blower motor, right wiper motor and air conditioner temperature control will fill with water when submerged and will probably experience early failure. The left hand wiper motor is sealed and should be okay.
10. Clean and replace fresh air filter.
11. Dry the radio, speakers and switches/controls inside the cab with hot air.
12. Disconnect all sealed electrical connections and clean and dry if water is present.
13. Remove all electronic control units; ccu, hcu, etc.. Disassemble units and clean and dry if water is present. Dry the internal components with hot air.
14. Rinse the alternator with clean water. When tractor can be started, observe the voltmeter for charge. If charge low, remove slip rings and brushes and clean. If battery level is overfilled, drain to full level and charge at low rate. If specifics gravity is less than 1.25, dump the battery fluid and refill with dry charge fill.
15. When the tractor has been reassembled and can be started, finish the hydraulic cleanup procedure as outlined in the technical manual. Run tractor at operating temperature for extended period to evaporate any remaining moisture.
Pete/ME
09-18-2004 02:45:05
Been through several floods. It's not the water, though that's bad enough, it's the silt that gets into everything. Silt is finer than sand but just as abrasive. To be sure you pretty much have to take the machine apart and clean everything; first with solvents, then with soap and water because anything that has oil or grease will hold the silt. You should also be aware that flood water and the residual residues may contain biological and chemical contaminates which can be very nasty stuff. Add a tablespoon of bleach to a gallon of water for cleaning, watch where the waste water goes and wear gloves and a respirator mask (not the paper kind). Good luck.
F-I-T
09-17-2004 18:09:03
RickD:
I think some one (maybe G-Man some months back) posted the official Deere instructions for resurrecting a submerged tractor. It's pretty involved, and at minumum requires multiple fluid changes after initial start up and warming.
At minimum, you'll have to drain and rinse the fuel tank, blow out all the lines you can, replace all the filters, remove the injectors and blow out the water from the cylinders, blow out the manifolds, replace the air filters after cleaning out the mud, blow dryer the starter and alternator, probably replace the battery, and only after you are sure you have dried out as much as possible, then, THEN, maybe crank it to throw out as much water as possible. Then you replace the injectors, start bleeding it point by point, and try to drain things into a glass or a test tube so you can see when it's clear and free of moisture.
Go to your dealer and get a copy of the official procedure and follow it. I bet he has several copies handy for his customers these days. As I recall, it was very detailed and if followed you have a chance of reclaiming her. But it's not a 100%.
This is not going to be a one morning job. Be patient, but get started right away before the water can begin to do further damage.
Good luck. You are in for a major chore.
Frank
