JD 50 Throttle Lever
BillS
09-17-2004 09:55:11
My throttle lever doesn't seem to want to stay at half throttle or so. I took it apart and noticed I need 2 fiber type washers. I went out to my local friendly JD dealer and he said sure that'll be 43.75 EACH. I beat a hasty retreat back to the barn to regroup and think out my next plan of attack. Does someone have an easy (and cheaper) fix? Thanks!
John Van Valkenburgh
09-17-2004 16:26:34
 Re: JD 50 Throttle Lever in reply to BillS, 09-17-2004 09:55:11
Bill,
I had the same problem on my 1953 model 50. I took was was left of one of the disks and made a template with cardbord. Next I put a new cutting disk on my air-cutting tool and ran it against a concrete block until I had the right diameter for the disk.
I took the disk and used a hollow punch to cut out the little section to match the original.
It's been working great ever since. It does not have to look perfect. Close will do.
Best of luck,
John
1953 Model 50
F-I-T
09-17-2004 11:25:58
third party image
I repaired a few of these by bonding a small cut-off wheels like is used for high speed die grinders. I used fresh urethane glue, and clamped it in place tightly. I removed the dried foam with a knife, and it stays put. You can't remove it without breaking it.
Couple of bucks at Home Depot or McMaster-Carr.
Frank
F-I-T
09-17-2004 11:23:15
third party image
Frank
Moline
09-17-2004 10:48:16
Carl is right.I just put one on my 60 and the dealer told me the same thing.(45.00 each!!!)You only need one.Deere has replaced the whole plate that bolts in there.The new one has the washers bonded to it.When I looked at my old plate it was pitted and rusted and would have taken out the new discs very quickly.Deere did me a favor by replacing the whole thing or I would have went through the washers quite regularly.Moline
Carl NY
09-17-2004 10:19:55
What the dealer did not explain is the individual friction washers have been replaced by bonding a material to the speed control plate, so you are buying a new updated version which is the entire steel speed control plate. I have used friction washers used in the fan assembly. Part # D 399R. The new speed control plate is coated on both sides, so you need only one.
CLW
09-17-2004 10:08:48
Others on here cut a leather disk from a boot or belt and it works good. I am surprised the dealer said he could get them at ANY cost. Have read on here that they can't get them. I got one in 96-97 for my 630 at Deere but a few years later folks started saying they couldn't get them anymore.
CLW
Mike M
09-17-2004 10:36:26
 Re: JD 50 Throttle Lever in reply to CLW, 09-17-2004 10:08:48
You would be suprised at the number of times my local dealer has told someone they could not get something or another only for me to look it up and give them the part number suddenly Deere has all kinds of them. Good help is hard to find.
