Directions on setting up a JD 55 Hydralic lift Plo
Tyler-MO
09-17-2004 06:29:22
Hello everyone,
I'm in the process of getting ready for my tractor club plow day in October. I recently purchased a model 55 ABH hydraulic lift plow. It is 3x14" old style bottoms (no shins, frogs, ect..only rebuildable shares and one piece moldboards)
Anyway, I thought I'd be smart and get a manual for it. Well, I searched around and thought that I'd found a manual for it, however ended up buying the setup instructions instead of the owners manual. It just talks about the steel wheel version and doesn't really discuss how to set the hitch for draft and tractor wheel spacing. My question is....does anyone have the instructions on how to properly set up the hitch on the plow and also what wheel spacing to achieve. I'm using my 720 gas row-crop tractor with 14.9-38" rubber. I have it set on 38" out from the center line of the tractor.
Please help me if you are able.
Thanks
Tyler in Missouri
F-I-T
09-17-2004 07:22:02
 Re: Directions on setting up a JD 55 Hydralic lift in reply to Tyler-MO, 09-17-2004 06:29:22
Tyler:
If you have an owner's manual handy for an older JD (for example, the setting up of pull type plows is well covered in my 70D manual) that should give you what you need. If not, I'll try and find a moment to scan something to post.
Frank
Plow Set up instructions.
09-17-2004 22:18:48
 Re: Directions on setting up a JD 55 Hydralic lift in reply to F-I-T, 09-17-2004 07:22:02
Try these links for Plow Set up instructions:
Page 1
Link
Page 2
Link
Page 3
Link
Plow 4
http://img.photobucket.com/albums/v16/Fboerger/Other%20pictures/Plow4.jpg
