B johndeere pulling tractor
Eric Self
09-16-2004 13:27:37
im in the 9th grade and i have put alot of money in the tractor. It looks really nice and has been bored .090 over. It's carburator has been rebulit and i had the head shaved, but it still spits and sputters and doesnt do good at the tractor pulls. What else should i do to it to make it pull better ??
JDBert
09-17-2004 05:37:53
 Re: B johndeere pulling tractor in reply to Eric Self, 09-16-2004 13:27:37
Eric, I had a 39' B I used to pull alittle and it did the same thing yours is doing. My problem turned out to be a rocker arm nut had come lose and I had a intake valve not opening very well. Probably not the problem in your case though, I would say its in your carb. If you have the resources I would get it on a dyno and play with it till you find the problem. Once you fix the problem go timeing>Carb at least twice to get it to optimum horse. If you want to go further then that, start playing with valve lashes and intake systems. Gutting the oil bath air cleaner will help you some. I installed a 4230 INNER filter in mine, but you might have to find a smaller one, as my buddy used a 4430 filter on his "G" but the 4430 was to big for my "A".
Bucky Reynolds
09-16-2004 18:27:36
hey eric its me... lol.. i dont know what to say about ur tractor cause i dont know anything.lol but i think u should but some spinners on that baby .. make it look real good...lol.. maybe some 22'lol....
G-MAN
09-16-2004 16:00:24
I'm sure you and WTW can get it figured out, but the one thing that caught my eye in your post was the part about the carb being rebuilt. A simple soak in carb cleaner and reassembly with new gaskets and needle and seat will not fix a carburetor with rust and crud in all the little passages in the carb body, and will not run correctly after the "rebuild". All the little brass plugs have to be removed and the passages cleaned with drill bits to remove the debris and rust. Robert's Carb Repair can properly rebuild your carb, or provide you with a video showing the proper procedure and also sell you the proper tools to do it yourself, if it comes down to that.
WTW
09-16-2004 14:41:44
Eric, I would be happy to help but will need more information. First what year is your tractor? What carburetor are you using? What type of ignition system do you have, a magneto or a distributor? Has anything been done to the ignition system? What is your ignition timing set at? What brand and number of spark plugs are you using? Is the cam stock? Does the engine run poorly all the time or just when it comes under load? Does the tractor start easy and does it idle nice? The best trouble shooting tips I can give you are ones I can make with most information about your tractor. If you can, answer as many as you can and I will start trying to figure out what you have going on otherwise it just a guessing game. If you would rather email me feel welcome to do so. I bet we can figure it out! B's are my favorite. Good Luck, Dave W.
Eric Self
09-16-2004 17:46:53
 Re: B johndeere pulling tractor in reply to WTW, 09-16-2004 14:41:44
Dave, it"s a 1952 B and it has a wico distributer. There has been nothing done to the ignition and we set the timing by ear. I run auto-lite c88 plugs and the cam is stock. The engine just runs poorly when put under a load and it does not crank easy or idle good. I know that the carburetor is a Marvel Schebler, but im not sure what the numbers are on it, i"ll try to find out. Thanks for trying to help
phil1
09-17-2004 13:14:57
 Re: B johndeere pulling tractor in reply to Eric Self, 09-16-2004 17:46:53
Check the choke coil spring. When it fails (jumps past the pin), the choke will move toward the "closed" position when the tractor is put on a load, that will cause it to spit and miss and run on only one cyl. Had it happen with my 1951B, it wouldn"t pull the sled more than halfway down the track.
JDG
09-16-2004 20:31:07
Also try auto lite plugs #3116. They work good in my "B".
JDG
09-16-2004 20:17:50
First get ride of Wico Dist. The are usually trouble!
