Fuel Pump question for Gerald J. or anyone else
Robby
09-16-2004 07:23:41
I was wondering what type of electric fuel pump you put on your 4020? How did you wire it? Mount it,ect? I would like to do this to my 3020.
thanks again!!!!! !!!!
Gerald J.
09-16-2004 08:06:03
 Re: Fuel Pump question for Gerald J. or anyone els in reply to Robby, 09-16-2004 07:23:41
I picked up a 3 psi "electronic" pump at Jocko's auto parts. 12 volts. NAPA had the same pump with their name on it for half again or twice the price. Rather rectangular in shape.
To mount it, I cut a piece of 3/32" steel from a scrap piece taken off the herbicide drive of a Cyclo 400 planter. It covers the original fuel pump opening, then bends up and out to provide a place to hold the electric pump with outlet above the inlet. I had to put a half inch stack of flat washers under the original pump studs because they weren't threaded all the way to the block.
The electric pump wants to be mounted with the fuel flow practically vertically going up. I put an elbow in each fitting. On the outlet I went to hose barb, then a couple inches of rubber hose to the hose barb on a fuel filter that has hose barb on one end and 1/8" pipe thread on the other. Then I adapted that pipe thread end with a right angle inverted flare to match the 4020 fuel line. I went to hose barb on the inlet and ran a longer hose to where the fuel line had been cut for an in line filter (that leaked).
I spliced the wire and connected it to the ignition switch side of the coil dropping resistor.
Haven't made any pictures.
Gerald J.
Robby
09-16-2004 08:51:11
 Re: Fuel Pump question for Gerald J. or anyone els in reply to Gerald J., 09-16-2004 08:06:03
Thank you very much.
